NWA55AXE as a repeater together with NWA50AX PRO (root AP)
Mar_Cin
Mar_Cin Posts: 9 image  Freshman Member
Hey Community!
I'm struggling with setting up NWA55AXE as a repeater together with NWA50AX PRO (root AP).. Is this something possible or not? Can you help me out?
I already own 2 x NWA50AX PRO and I wanted to extend my network outside my house by connecting NWA55AXE to one of my NWA50AX PRO by enabling smart mesh on all devices AP. I manually selected Uplink for NWA55AXE to point one of my NWA50AX PRO (the other has Downlink disabled in smart Mesh options)
I applied all configuration, I wated 10-15 minutes until NWA55AXE aquired configuration from Nebula and then I disconnected LAN from NWA55AXE hoping it will connect eventually with my current AP.. but that didnt happen…
What Im doing wrong? do I missing something?
I was looking at knowledgebase articlles and tutorials, but so far no luck…
Any Idea?
Please help
Mar_Cin
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    edited September 2024 Answer ✓
    Hi @Mar_Cin ,
    Should I leave 2.4GHz radios all DCS? or should I fix them on a specific channel?
    We recommend setting DCS to AP scan mode and select the optimal channel for your network environment.
    Should Repeater and root AP be on the same channel if i decide to set them manually?
    The repeater and root AP should operate on the same channel.
    Note that: signal strength decreases with distance and obstacles (e.g., doors, walls). For best performance, maintain line-of-sight between your root AP and repeater AP.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    HI @Mar_Cin ,
    In case the smart mesh connection couldn't be established, please:
    • Make sure APs are provisioned using wired connection before deploying repeater APs into their actual positions. All APs must show configuration status is "Up to date" before deployment.
    • Fine-tune the deployment of root and repeater location. APs must be deployed in the signal covered area (recommended –70dBm or above) while uplink AP is within line-of-sight of repeater.
    For more detailed information please refer to:
    [Nebula] How to extend wireless coverage by configure smart mesh? — Zyxel Community
    If you've followed the above recommendation and the issue persists, please enable Zyxel support.
    Additionally, please provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
    Zyxel_Judy
    Untitled Image
  • Mar_Cin
    Hi @Zyxel_Judy
    While I was waiting for your response, I was able to set up things correctly… I took me AGES to figure it out… and NWA55AXE takes ages (~20min - very concerning!) to sync config with cloud (unlike my other 2 NWA50AX Pro ~1-2 mins…)
    I had to use 2.4Ghz interface, as 5Ghz signal was too weak in the deployment area
    Now its around -66dB with Uplink TX/RX ~154/154 - which is kind of poor, but root AP is inside my house, and NWA55AXE is outside 10m away from house - I need to rethink how to manage that.
    I have a question in regards to Radio settings configurations..
    Mar_Cin
  • Zyxel_Judy
    Hi @Mar_Cin ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
