AP with no "Neighbor Info" on "Nebula Control Center"
i'm new on Nebula Cloud. We have a site with 50 APs.
On Side-Wild → Topology page i can find the neighbor information on all APs.
On Side-Wild → Devices → Access Point page, for some APs (random APs that change randomly over time) the filed "Neighbor info" is empy.
Someone can tell me the reason or a workaround to see the "Neighbor info" for all APs?
Thanks,
Mauro_MEAD
Hi @Mauro_Mead,
Thanks for your privilege.
After checking, this issue is related to the switch offline. We will fix this issue on 10/21.
Zyxel Melen0
Hi @Mauro_Mead,
Could you help enable Zyxel support access so I can check this issue?
By the way, is your APs connecting to a management switch or an un-management switch?
Zyxel Melen0 -
Hi Zyxel_Melen,
Thanks for the reply. All the switches are managed. Models XS1930-12HP, XGS2220-30HP, GS1920-8HP.
I've also opened a ticket following the guide you provide.
Hi @Mauro_Mead,
Zyxel Melen0 -
Hi Zyxel_Melen,
thanks for the info. I'll check the cloud portal afther the update.
Mauro.
Hi Zyxel_Melen
i confirm that after the Nebula upate the issiue is resolved. Now i can see the neighbour on every AP in Devices—>Access Point section.
Mauro
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
