Unstable Wifi
Dpj
Dpj Posts: 215 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
hello all.
We have placed a few months ago an complete new network at a customer.
We only use zyxel devices, connected to nebula.
We have issues with the wifi. Last week i was at the customer site, and i was connected to the wifi. One moment i had 80mbps up/down, the following moment i just had something beteween 0,8 and 3 mbps. The next moment 80 again.
I'm reviewing the logging. And what i see is from time to time an reason 5 error message in the nebula logging. We have placed 4 wifi devices at this side, and i got the reason 5 from multiple devices.
I have to find out what i can do about this error. It seems the accesspoint is to busy to handle all the traffic.
for your information:
the device is an NWA1123-AC PRO. I see the messages as wel from the 2.4 as the 5 ghz.
I also see reason 3 messages, but that has only to do with roaming from 1 accesspoint to the other Access point?
thx for your help and support.
Best Answers
  • Zyxel_Kay
    Hi @Dpj
    The "Reason 5" errors in your Nebula logs indicate that the access point (AP) disassociated your device because it may be overwhelmed by traffic or too many devices connected simultaneously. This can be caused by high client density, excessive traffic, or suboptimal AP placement.
    Regarding the "Reason 3" messages, these typically occur during normal roaming when a device disconnects from one AP to connect to another. However, if the device is far from the AP or obstructed by walls or other interference sources, it can also cause these errors.
    Here are a few suggestions to help improve your network performance:
    1. AP Placement: We recommend placing indoor APs every 15 meters as a general guideline, but the actual distance depends on the environment and traffic. You can refer to this post for more information:
    2. Managing Traffic: If you have many devices connected, consider managing the number of concurrent connections or applying speed rate limits to avoid congestion:
    3. Interference: Make sure your APs are positioned away from potential sources of interference. This post explains common causes of WiFi interference:
    4. Bandwidth Availability: Check that your network infrastructure (router, modem, firewall) has enough bandwidth to handle the traffic load. If your traffic is consistently high, consider upgrading your network equipment or internet plan.
    5. Optimizing Nebula AP: You can follow these guidelines to optimize your AP settings for better WiFi performance:
    If you've tried these optimizations and are still experiencing issues, please enable Zyxel Support on Nebula Control Center (NCC) and provide us with your organization and site name. Additionally, it would be helpful to know which device(s) (e.g., MAC address) are having connectivity difficulties. You can share this information via private message for privacy reasons.
    Kay
  • Zyxel_Kay
    Hi @jpblanch75
    To assist further, could you let us know if there’s a specific aspect of the issue you'd like us to revisit or if any new symptoms have appeared since your last post? We'll do our best to dive deeper into the potential causes and work with you toward a resolution.
    Kay
  • Zyxel_Kay
    Hi @Dpj
    Kay
  • Dpj
    Thank you for your information, tomorrow we will take a look at it remote! i will keep you informed!
  • jpblanch75
    jpblanch75 Posts: 185 image  Master Member
    First Comment Friend Collector Third Anniversary Community MVP
    I have similar issues on the 2.4 band. I've been bring this up for quite a while but its not taken seriously.
  • Zyxel_Kay
    Hi @jpblanch75
    To assist you further, could you please provide a few more details?
    • Which device model are you using?
    • Could you describe the specific symptoms you’re experiencing, and in what ways they seem similar to those in this thread?
    • How is your access point managed—standalone, through Nebula, or via a controller? If managed through Nebula, could you enable Zyxel Support access and provide your organization and site name?
    With this information, we’ll be able to investigate more effectively.
    Kay
  • Zyxel_Kay
    Hi @jpblanch75
    After reviewing the forum thread you mentioned, it appears that the client's disconnection from the access point is due to the client device itself. Specifically, disconnection reason 8 indicates "Disassociated because sending STA is leaving (or has left) BSS," meaning the client device initiated the disconnection.
    In that thread, however, the original poster experienced reasons 5 and 3, which differ from your case. These reasons are more related to network traffic and environmental factors. You may consider sharing more details in that thread, as it will provide our team or other users with a clearer understanding to assist you further.
    Kay
  • jpblanch75
    I've shared a lot in my opinion….. it got no where.
  • Zyxel_Kay
    Hi @jpblanch75
    Kay
