NAS542 - Unable to connect to myZyxelCloud
I'm running a NAS542, V5.21(ABAG.15) and i ping correctly in Network Diagnosis and the router is detected as UPNP.
I read the cloudagent.log and found this error:
[2024/10/16-12:39:36] pair status checking: "NON-PAIRED" and no cloud user exists, do nothing
[2024/10/16-12:39:37] connection disconnected: Error: 15 Reason: SSL peer presented an invalid certificate
[2024/10/16-12:39:37] re-connect delay time: 39958 ms
[2024/10/16-12:40:53] RESTFUL: device register success, and http code is 200
[2024/10/16-12:40:53] agent reconnect: restful success
[2024/10/16-12:40:53] sync pair status "NON_PAIRED"
[2024/10/16-12:40:55] NAT type detect:5, Hairping:0 [52.5.137.202]
[2024/10/16-12:40:55] pair status checking: "NON-PAIRED" and no cloud user exists, do nothing
[2024/10/16-12:40:55] re-connecting...
What can i do?
Thanks, Ivano
I have the same problem and my log file looks the same
Same for me! Now it's October 24 and I am not able to see my NAS326 from the online domain. I'm quite sure that there is some issue on the MyZyxelCloud service from Zyxel itself
It is necessary to reinstall myzyxelcloud agent. It fixes the problem
The same problem.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
