AP with no "Neighbor Info" on "Nebula Control Center"
Mauro_Mead
Mauro_Mead Posts: 4 image  Freshman Member
i'm new on Nebula Cloud. We have a site with 50 APs.
On Side-Wild → Topology page i can find the neighbor information on all APs.
On Side-Wild → Devices → Access Point page, for some APs (random APs that change randomly over time) the filed "Neighbor info" is empy.
Someone can tell me the reason or a workaround to see the "Neighbor info" for all APs?
Thanks,
Mauro_MEAD
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @Mauro_Mead,
    Thanks for your privilege.
    After checking, this issue is related to the switch offline. We will fix this issue on 10/21.
    Zyxel Melen
Nebula Tips & Tricks
