LTE firmware for SBG3600
1568101120
  • ApTyp
    ApTyp Posts: 2  Freshman Member
    edited December 2018
    Zyxel_Vic said:
    Hi @ApTyp @Nico2786
    I'll send you the module firmware via private message. Before that, can you try to downgrade the firmware back to the original version and see if it helps?
    BIG Thank you! Now its working =)) I just upload new LTE firmware after that Signal Quality: change to GOOD signal and starting working )))
    Software Version: V1.00(AAKO.9)
    Module Firmware Version: ALT3100_05_00_02_00_81_MS
  • esuomala
    esuomala Posts: 1  Freshman Member
    Hello! I also got bad LTE after uppgrading my SBG3600-N000 to AAKO.9 and I'm also on ALT3100_04_05_06_10_B8_LO.
  • Zyxel_Vic
    Zyxel_Vic Posts: 310  Zyxel Employee
    25 Answers First Comment Friend Collector Seventh Anniversary
    Hi @esuomala
    I'll private message you the module firmware. You may have a try with it.
  • svenmoog
    svenmoog Posts: 1  Freshman Member
    Hello! I also got bad LTE after uppgrading my SBG3600-N000 to AAKO.9.
    Can you send ime a PM too!
  • Kepler
    Kepler Posts: 1  Freshman Member
    Hi
    I got really bad LTE with my SBG3600-N000 on V1.00(AAZN.8) Firmware.
    LTE Firmware using at the moment: ALT3100_04_05_06_10_B8_LO
    Can you send me the new LTE Firmware?
  • Alfa3a
    Alfa3a Posts: 1  Freshman Member
    First Comment Sixth Anniversary
    I have too poor results performance with lte firmware version ALT3100_04_05_06_10_B8_LO, where i can find latest ?
  • Zyxel_Vic
    @svenmoog
    @Kepler
    @Alfa3a
    I'll send you the module firmware in private message. Please have a try on it.
  • Ronca
    Ronca Posts: 1  Freshman Member
    Hi
    Same issue here
    Thank you very much!
  • Aivpod
    Aivpod Posts: 1  Freshman Member
  • distro
    distro Posts: 1  Freshman Member
    Hello. I'd also like the new firmware versions :)
