Trying to setup NCC content filtering.
Mr_IT_4_Life
Mr_IT_4_Life Posts: 13 image  Freshman Member
Can anyone please tell me what this error message mean ? and how to solve it ?
Trying to set up Parental Control on my nsg100
  • Zyxel_Kay
    Hi @Mr_IT_4_Life
    The issue has been resolved. You can now set up the NSG100 Content Filtering feature on Nebula CC without any further issues.
    Thank you for your patience and understanding!
    Kay
  • Zyxel_Kay
    Hi @Mr_IT_4_Life
    Could you please help to enable Zyxel Support access and share your Nebula organization and site name? This will allow us to investigate your site further.
    Kay
  • Mr_IT_4_Life
    activated support access.
    org and site : Villaholmen
  • Zyxel_Kay
    Hi @Mr_IT_4_Life
    We have identified an issue with this feature, and our team is actively working on a fix. We will keep you updated with any progress.
    We apologize for any inconvenience caused and appreciate your patience.
    Kay
  • Zyxel_Kay
    Hi @Mr_IT_4_Life
    Kay
Nebula Tips & Tricks
