Nr7101 reconnect time
Hi, is there a reason why nr7101 keep too much time to reconnect to network? It's more than 60 seconds.
Chateu 5g with same platform keep few seconds, 5 at max.
My isp disconnect 4 times in a day, and 60-70 seconds without internet each time is too much.
UP
Hi, in my experience, the minimum was 40 seconds. Never less.
Usually it takes longer if you add band selection or tower/cell lock.
Hi, in my case router mode it takes 50/55 seconds withouth band/cell selection.
Hi, checked in router mode, it takes less but 50/55 seconds.
Have you tried to enable the log (Maintanence > Log Settings)? You should enable Cellular WAN and ESMD in order to see where's the issue.
I tried, but cannot see any log in that page, blank output. What could i miss?
More, ethernet interface goes down when modem reconnect and webpage is not reachble.
The problem is your ISP, not the modem so.....
Why do they disconnect?
My ISP never shut down so i'm a bit confused why yours do?
They use this policy for all consumer sim, reconnect each 4 hour. I don't know the reason.
Anyway i don't agree, reconnect time of 1 minute is not my isp problem, but router problem. Other brands router keep from 3/5 to 12 seconds at max for reconnecting. Tested by myself with same sim and bts.
I have it like:
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
