How do I download a folder of files/multiple files at once on my NAS? (542)
Oscwo
Oscwo Posts: 40 image  Freshman Member
edited October 2024 in Personal Cloud Storage
So I have several folders with RAR files containing up to 100 files in one folder.
File browser won't let me download a whole folder, it also won't let me select multiple files at once and download them all.
Surely there must be a way somehow to get the entire folder to my PC without having to make 100+ individual downloads from the folder?
Best Answers
  • Oscwo
    Turns out SMB1 is not enabled on Windows 10 by default. I enabled that and now my NAS folders are accessible under the network tab in explorer.
    Thanks for the help.
  • Mijzelf
    Mijzelf Posts: 2,982 image  Guru Member
    What I wonder though is if there is a way that you could transfer files to the NAS from Explorer?
    It should just work. When you open a share in Explorer, it should work like a local drive. (Well, a bit slower, of course).
    Maybe you configured the shares to be readonly over samba? That can be configured in the users&shares menu.
«1
  • Mijzelf
    Use Samba. "Windows filesharing".
  • Oscwo
    Do you know of any good tutorials for this? The one I've found starts by saying I should open Terminal on my Linux machine. Is that even possible on the NAS?
  • Mijzelf
    Yes, that is possible, but way beyond the goal. Samba is already running on the NAS. Actually it's the main function of the NAS.
    You only have to configure your client to access it. If you are on a Windows PC, all you have to do is typing
    \\<ip-of-nas>\
    in the address bar of explorer. On Linux (and maybe also on a Mac) you can in most cases type
    smb://<ip-of-nas>/
    in the address bar of the file browser.
  • Oscwo
    Oh ok thanks for the clarification. That sounds way easier than what I imagined.
    I tried typing exactly what you wrote in my Windows explorer window and it gave me "\\<ip-of-nas>\ is not acessible". (I'm paraphrasing because I have Windows in a different language)
    I'm currently connected to the NAS through my browser so no issues there.
    Do you know what the problem is?
  • Mijzelf
    No directly. You are aware you should exchange <ip-of-nas> by the actual ip address of the NAS?
  • Oscwo
  • Mijzelf
    Is you client in the same network as the NAS? And are you accessing it on it's local IP? Samba is not designed to be used across the internet, and many ISP's block it.
    A firewall can be a problem. When I remember well, when you connect a Windows PC to a new network it gives you the choice between 3 levels of firewall protection: Public network, Home network and Corporate network. (The actual used names will be different). In case of Public network I think it won't allow samba connections. So for a test try to switch of the firewall.
  • Oscwo
    Have Windows on a private network currently. I tried turning off the firewall and now the error message is gone. Instead now, typing <ipofnas> into explorer opens a web-browser window…That window is just empty though.
    Same when I turn the firewall back on. What is supposed to happen? And any idea what's wrong?
  • Mijzelf
    That should be \\<ipofnas\. Without the double backslash Explorer has to guess which protocol to use. And I think it defaults to http. Don't know why that yields an empty page though.
  • Oscwo
    Hm…Ok when I try that it again gives the error message that it is not accessible. When I click the diagnose-option it specifically says that the DNS-server is not available/found. Not sure what that means or if it's relevant.
    Any more ideas?
