LTE7490 in Routing mode (multi-WAN setup)
Zio
I own an LTE7490-M904 LTE router and I am having troubles setting it up in Routing mode (IP passthrough is not an option).
The target setup is as follows:
- LTE7490 acting as a router on fixed IP internal interface (i.e., 192.168.2.1)
- Multi-WAN router port configured with fixed IP (i.e., 192.168.2.2) using the LTE7490 as default gateway (and DNS proxy) on 192.168.2.1
- Access to the LTE7490 web configuration interface through LAN on 192.168.2.1
- LTE7490 acting as WiFi AP, for internet and access and LTE7490 web configuration interface
Something like this:
I have tried many configurations so far, but even with the simplest setup the LTE7490, when in Router mode, cannot be pinged (and no internet access is available on either interface, LAN or WiFi).
Is this configuration supported? If yes, how shall the LTE7490 be configured?
Thanks!
Hi Zio,
- The LTE7490's Wi-Fi is only for local management. It does not support accessing the Internet.
- For the LTE7490's LAN, if the end device gets an IP address from the LTE7490 instead of setting a static IP address, can the end device receive ping response from the LTE7490?
- What is the LTE7490's firmware?
Regards,
Bob
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
