Multi m1 5g WiFi no internet connection
Here's a corrected version of your text:
"When I connect to the 5G network mesh, I lose connection to the internet. However, the 2.4GHz network works fine. After rebuilding the entire network (hard resetting the satellites), it works for a while but then the issue returns. How can I fix this?"
Hi @ireckx,
Please help to clarify:
- Can you ping 8.8.8.8 when the issue happened?
- Can you resolve DNS, like google.com, when the issue happened?
- Do you have many Multy M1 and this issue only happens when you connect to satellites?
If Q1&Q2 is no, and/or Q3 is yes, please help to send us the feedback on the Multy APP.
You can follow the below steps to send feedback on the Multy APPOur agent will check this issue after you send it.
Zyxel Melen0 -
Thanks for the answer. It's exactly as you described, alredy sent. But I sent feedback many times and nothing happen.
Hi @ireckx,
Since sending feedback will use your email to send it out, could you help check if it is in your drafts or sent folder? If so, you can change the network and send it again.
Please feel free to let me know if you still cannot send it.
Zyxel Melen0 -
Do you have any idea? Support not responded. I have 4 devices and cannot use 5g network at all.
Hi @ireckx,
I have sent you some requests for this issue, please check your forum message box. Thanks.
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
