my main hub has internet connection but when I try to add my second Multy X it does not connect
Hi @Paul_Morgan99,
Could you describe more details about your issue?
Do you mean the Internet connection loss when you connect second Multy X to the hub or?
Zyxel Melen0 -
Following a storm my whole internet connection was lost for a day. My primary Multy X (in my study) has connection to the Internet but my second Multy X (in my lounge) does not connect. The light on top is red. I have tried to reboot many times but the second Multy will not link to my primary.
Best regards
Hi @Paul_Morgan99,
Thanks for the description.
- May I know if the connection between the first and the second Multy X is wired or wireless?
- Did the second Multy X connect to the first one before?
- If it is wireless, please make the second Multy X near to the first one or use weird connection.
Zyxel Melen0 -
Hi
- It's wireless
- Yes, it worked fine before my internet connection was lost for a day
- Yes I tried the wireless connection between my two Multy Xs just a few metres apart in the same room. the second router would not connect (red light). I have not checked the connection with a cable between the two.
Hi @Paul_Morgan99,
Thanks for your update. Please help to send us the feedback on the Multy APP.
You can follow the below steps to send feedback on the Multy APPOur agent will check this issue after you send it.
Zyxel Melen0 -
@Paul_Morgan99 did you fix the problem? I have the same problem.
No afraid not, I purchased a new system from TP-Link.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
