Multi m1 5g WiFi no internet connection
ireckx
ireckx Posts: 3 image  Freshman Member
Here's a corrected version of your text:
"When I connect to the 5G network mesh, I lose connection to the internet. However, the 2.4GHz network works fine. After rebuilding the entire network (hard resetting the satellites), it works for a while but then the issue returns. How can I fix this?"
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,587 image  Zyxel Employee
    Hi @ireckx,
    Please help to clarify:
    1. Can you ping 8.8.8.8 when the issue happened?
    2. Can you resolve DNS, like google.com, when the issue happened?
    3. Do you have many Multy M1 and this issue only happens when you connect to satellites?
    If Q1&Q2 is no, and/or Q3 is yes, please help to send us the feedback on the Multy APP.
    You can follow the below steps to send feedback on the Multy APP
    Our agent will check this issue after you send it.
    Zyxel Melen
  • ireckx
    Thanks for the answer. It's exactly as you described, alredy sent. But I sent feedback many times and nothing happen.
  • Zyxel_Melen
    Hi @ireckx,
    Since sending feedback will use your email to send it out, could you help check if it is in your drafts or sent folder? If so, you can change the network and send it again.
    Please feel free to let me know if you still cannot send it.
    Zyxel Melen
  • ireckx
    Do you have any idea? Support not responded. I have 4 devices and cannot use 5g network at all.
  • Zyxel_Melen
    Hi @ireckx,
    I have sent you some requests for this issue, please check your forum message box. Thanks.
    Zyxel Melen
