NSA325v2: Transmission default download folder
#NAS_Nov_2018
I have found a way to achieve this!
1. In web UI, disable Transmission package
2. If not enabled, enable Telnet in web UI
3. Connect to the NAS via telnet. Login as root
4. Run vi /usr/local/zy-pkgs/config/Transmission/settings.json and edit the setting download-dir to desired folder. I have changed to /i-data/md0/video/ which is the built-in Video share.
5. In web UI, enable Transmission package. Now all files are placed to desired folder by default :)
6. Disable telnet.0
I think it is not possible, I did the check also, and as what you did, no option to change default folder in Transmission, moreover, I tried to use hard link to mirror new folder as transmission download folder via telnet, but it always show operation not permitted.
The only option I think is use NSA325 v2 default download server, and it is possible to change default download place.0 -
6. Disable telnet.0 -
Have been looking to solve this myself but I did not manage by following your steps. Do you mind clarifying or seeing if I did something wrong?
When I follow step 4 here I get:
~ $ vi /usr/local/zy-pkgs/config/Transmission/settings.json
~- /usr/local/zy-pkgs/config/Transmission/settings.json 1/1 100% "
I then enter:
/i-data/md0/"Nameofmyfolder/
and get: Pattern not found.
I feel like I might have missed a step?
Many thanks
The location of the file on a NAS is different from the location on an NSA. At least the configurations of the packages, and the packages itself are separated from each other. I'd expect the package in
/i-data/md0/admin/zy-pkgs/Transmission/
but I don't know if the settings file is in …/config or …/etc.
Thanks for the input
So you are saying to execute
/i-data/md0/admin/zy-pkgs/Transmission/ "
On the last step? Have you heard of any other way of solving this problem? I have tried both to delete and reinstall the app, specifically downloading it to my new volume but the download folder is still located in my "Volume 1".
I have even tried to delete that folder but Transmission automatically creates a new one there.
Frustrating…
'Execute' is the wrong word here. You are executing vi, with as commandline parameter the file you want to edit. The config file for Transmission on a NAS is probably '/i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json' (And forget the other path I gave, it's a mistake).
I have to apologize because I'm completely experienced with this language and SSH in general.
Ok, so I Execute vi.
Then, you give me this:
/i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json"
That sounds to me like just a file path to where the settings are. How do I then actually edit these settings? (What is the command I need to write?).
When I loged in as Admin and then run:
" vi /usr/local/zy-pkgs/config/Transmission/settings.json "
Followed by:
" /i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json "
I get "Path not found".
Many thanks.
The editor is vi, the file-to-be-edited is '/i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json', so the full command to use the editor to open that file is
vi /i-data/sysvol/.PKG/Transmission/config/Transmission/settings.json
Thanks again Mijzelf,
That command seems to work I guess but what I wonder is how to use the editor?
If my current download folder is "Transmission" on "Volume 1" and I want to change it to "Transmission" on "Volume 3" …
What command(s?) would have to be entered?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
