NSA325v2: Transmission default download folder
13»
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Btw, the last bit of code you gave to remove the faulty directory did not give any feedback to indicate it worked. Maybe that is as it should be?
    Yes. 'Successfully removed X' is sort of superfluous, as that was to be expected. You get only feedback when something unexpected happens.
