NAS326 Slow Ethernet Transfers after Win 11 Upgrade
I did a clean install the other day to take me from Windows 10 up to Windows 11 and ever since, my transfer speeds to my NAS326 have been substantially slower (around 17MB/s tops). Previously I would get speeds of at least 80-100 MB/s, so transferring files from my PC to the NAS is taking easily 4x longer compared to before.
Nothing has changed with my PC or network hardware, nor the configuration. I have tried swapping cables as well. The NAS and my PC are both connected via ethernet directly to my router, and the NAS has a static IP address with its adapter showing "1000 Mbps, full-duplex". I'm on a 1000Mbps internet connection and the NAS is mapped via Windows File Explorer. I'm using up to date drivers for ethernet on my PC and the NAS firmware is current.
I have noticed that, while transferring, the NAS CPU is pinned at 100%. I'm not sure if this was ever the case before because I can't say that I looked, but I think that may be worth mentioning.
Any help would be greatly appreciated!
A new OS is categorized as nothing? I can say you nothing has changed with the NAS, so you should really look at the PC.
I wonder if your new OS forces encrypted data transfer. Encryption is expensive, and it wouldn't surprise me if encrypting 17MB/sec maxes out the CPU. Maybe this can help?
https://www.elevenforum.com/t/enable-or-disable-require-smb-client-encryption-in-windows-11.19242/
Sorry, I meant nothing has changed about my PC's hardware as I'm sure you deduced after my mention of the Windows upgrade.
I tried following that guide previously and it looks like it wasn't affecting the speeds, as nothing changed when I disabled the encryption. I'm really stumped here!
- 441 Beta Program
- 292 Service & License
