NAS540 FW:V5.21(AATB.13) - HDD Sleep function not working
@Mijzelf Many thanks for your reply. Found the uninstall button. (Earlier I didn't see it because I was using the web interface on my mobile phone. Screen too small.)
So I uninstalled it. After reboot, it comes back. So I proceeded to get MetaRepository by creating web_prefix with the url
http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
as instructed. From App Center I pressed Browse, All Apps. Then it showed "Retrieve List From Internet", a few seconds, then "Download List Fail". I tried several times, same error. All standard apps still show, but no MetaRepo.
Any idea what went wrong?
Yes. The instructions I pointed to nowhere tell you to create a web_prefix file. It tells you to download one. And zyxel.diskstation.eu is no more, it's zyxel.ddnss.eu now.
Sorry, I missed out on the link you provided. So I searched the web and found the outdated instructions.
Will try again with the link you provided.
@Mijzelf Hi, I just had time to try again with the latest instructions. The MetaRepository package was installed successfully and enabled. I pressed the refresh again and now I see MetaRepo together with the other standard packages in App Center. Then I pressed Launch on MetaRepo for the config page.
Now this is the part where I'm not sure if I did the right thing. I leave one entry http://zyxel.ddnss.eu/Users.....and removed everything else from the config box. Click Apply. Then go back to App Center and click refresh again.
I still don't see any new packages showing up for installation.
Am I supposed to see the Tweaks packages in App Center so that I can install them?
Then I uninstalled MetaRepository and installed it again. This time I use the default config without changing anything. Just clicked apply.
Same result.
In \\<NAS>\admin\zy-pkgs\ there should be a logfile now. Can you post that?
HandleZYPKG_INFO /NAS326/zypkg/5.21
FindApp md5sum found /sbin/md5sum
ReadConfig Repositories
Start of block
ftp://ftp2.zyxel.com/+ ZyXEL
http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ Mijzelf
/i-data/sysvol/admin/MyRepo/ Local
End of block
8 start: 09:01:14
7 start: 09:01:14
9 start: 09:01:14
7: FetchZYPKG_INFO /i-data/sysvol/admin/MyRepo/ 7 Local
8: FetchZYPKG_INFO http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf
9: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ 9 ZyXEL
7: FindApp curl found /usr/bin/curl
8: FindApp curl found /usr/bin/curl
9: FindApp curl found /usr/bin/curl
7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
7: Failed
7 stop: 09:01:14
8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
9: Failed
8: Failed
9 stop: 09:01:14
8 stop: 09:01:14
Nothing changed
TarHeader
Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz - succeeded
TarHeader
In the webinterface of MetaRepository, change 'downloads.zyxel.nas-central.org' to zyxel.ddnss.eu. The rest of the URL remains unchanged.
The problem here is that MetaRepository on installation changes the URL of it's 'main' repository by reading the log of the package manager, to see where the package was downloaded from.
By un- and reinstalling MR the package manager took the MR.zypkg file from the cache, so it wasn't downloaded, and the installed MR couldn't do the swap trick.
I uninstalled MR, then installed MR, launch config, change the serverv url as you instructed (keeping original path), Apply. Then go to App Center, browse all apps. No new packages.
Here is the new log:
Start of block
http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ Mijzelf
End of block
9 start: 18:26:53
7 start: 18:26:53
8 start: 18:26:53
8: FetchZYPKG_INFO http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf
7: Failed
7 stop: 18:26:54
8: Fetch http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp succeeded
8: tar: invalid tar magic
8: rm: can't remove '/i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw5_.520.md5': No such file or directory
8 stop: 18:26:55
9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp succeeded
9 stop: 18:27:01
Pushlist...
ReadConfig Pushlist
Start of block
End of block
Blacklist...
ReadConfig Blacklist
Start of block
YouNameIt
End of block
/bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/List.3224
Sort...
Choose packages...
Choose DEPS...
Choose SUPPKG...
Create ZYPKG_INFO.tgz
TarHeader
Whoops. That is a misconfiguration in the server. This should have failed, but it didn't. I'll inform the server admin tonight.
As a work-around you can create a directory \\<NAS>\admin\MyRepo\ on your NAS, and put ZYPKGS and Tweaks_20200310_arm_035.zpkg (and other packages you'd like to install) in it, from http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
