NAS 542 shutss off just after starts
Tread
Tread Posts: 4 image  Freshman Member
I have a NAS 542 that is a few years old. When I turn it on, the device starts spinning the disks, starts up, and the login screen appears. At this point, you can enter your username and password, and the device starts logging in, but after a while you hear a BIP and the device turns off.
What is causing this and how can I fix this problem
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Did you have timed shutdown activated? In the past that function has proven to be able to go haywire. In that case a factory reset could solve the problem.
    When the box has beeped to indicate the booting is done, push the reset button on the back, and keep it pressed until the box has beeped 3 times.
  • Mijzelf
  • Tread
    Yes, I did. It was scheduled to go down every day at 01:00 and start up at 09:00.
    Will try to reset and will let know here the results.
  • Tread
    edited January 2025
    Now device is booting up and stays on and seems that original problem was solved (thank you very much!) but I cannot access NAS via network (I cannot connect to login page). Tried to use http://NAS542/ or https://NAS542/ or find it in local network but it does no show there. Also green LED is not light and amber LED is blinking on Ethernet port. Seems now it is some network problem.
  • Mijzelf
    Have you tried the other ethernet port?
  • Tread
    edited January 2025
    @Mijzelf Thanks to your advice I was able to reset NAS and it works as before :) Thank you again!
