NAS540 FW:V5.21(AATB.13) - HDD Sleep function not working
  • artwich
    artwich Posts: 15 image  Freshman Member
    edited January 2025
    @Mijzelf Many thanks for your reply. Found the uninstall button. (Earlier I didn't see it because I was using the web interface on my mobile phone. Screen too small.)
    So I uninstalled it. After reboot, it comes back. So I proceeded to get MetaRepository by creating web_prefix with the url
    http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
    as instructed. From App Center I pressed Browse, All Apps. Then it showed "Retrieve List From Internet", a few seconds, then "Download List Fail". I tried several times, same error. All standard apps still show, but no MetaRepo.
    Any idea what went wrong?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Yes. The instructions I pointed to nowhere tell you to create a web_prefix file. It tells you to download one. And zyxel.diskstation.eu is no more, it's zyxel.ddnss.eu now.
  • artwich
    Sorry, I missed out on the link you provided. So I searched the web and found the outdated instructions.
    Will try again with the link you provided.
  • artwich
    edited January 2025
    @Mijzelf Hi, I just had time to try again with the latest instructions. The MetaRepository package was installed successfully and enabled. I pressed the refresh again and now I see MetaRepo together with the other standard packages in App Center. Then I pressed Launch on MetaRepo for the config page.
    Now this is the part where I'm not sure if I did the right thing. I leave one entry http://zyxel.ddnss.eu/Users.....and removed everything else from the config box. Click Apply. Then go back to App Center and click refresh again.
    I still don't see any new packages showing up for installation.
    Am I supposed to see the Tweaks packages in App Center so that I can install them?
    Then I uninstalled MetaRepository and installed it again. This time I use the default config without changing anything. Just clicked apply.
    Same result.
  • Mijzelf
    In \\<NAS>\admin\zy-pkgs\ there should be a logfile now. Can you post that?
  • artwich
    HandleZYPKG_INFO /NAS326/zypkg/5.21
    FindApp md5sum found /sbin/md5sum
    ReadConfig Repositories
            Start of block
            ftp://ftp2.zyxel.com/+ ZyXEL
            http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ Mijzelf
            /i-data/sysvol/admin/MyRepo/ Local
            End of block
    8 start: 09:01:14
    7 start: 09:01:14
    9 start: 09:01:14
    7: FetchZYPKG_INFO /i-data/sysvol/admin/MyRepo/ 7 Local
    8: FetchZYPKG_INFO http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf
    9: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ 9 ZyXEL
    7: FindApp curl found /usr/bin/curl
    8: FindApp curl found /usr/bin/curl
    9: FindApp curl found /usr/bin/curl
    7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
    7: Fetch /i-data/sysvol/admin/MyRepo/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_MyRepo_.tmp failed
    7: Failed
    7 stop: 09:01:14
    8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
    9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
    9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp failed
    8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/fw5/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
    9: Failed
    8: Failed
    9 stop: 09:01:14
    8 stop: 09:01:14
    Nothing changed
    TarHeader
    Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz - succeeded
    TarHeader
  • Mijzelf
    In the webinterface of MetaRepository, change 'downloads.zyxel.nas-central.org' to zyxel.ddnss.eu. The rest of the URL remains unchanged.
    The problem here is that MetaRepository on installation changes the URL of it's 'main' repository by reading the log of the package manager, to see where the package was downloaded from.
    By un- and reinstalling MR the package manager took the MR.zypkg file from the cache, so it wasn't downloaded, and the installed MR couldn't do the swap trick.
  • artwich
    I uninstalled MR, then installed MR, launch config, change the serverv url as you instructed (keeping original path), Apply. Then go to App Center, browse all apps. No new packages.
    Here is the new log:
    Start of block
    http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ Mijzelf
    End of block
    9 start: 18:26:53
    7 start: 18:26:53
    8 start: 18:26:53
    8: FetchZYPKG_INFO http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf
    7: Failed
    7 stop: 18:26:54
    8: Fetch http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp succeeded
    8: tar: invalid tar magic
    8: rm: can't remove '/i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw5_.520.md5': No such file or directory
    8 stop: 18:26:55
    9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp succeeded
    9 stop: 18:27:01
    Pushlist...
    ReadConfig Pushlist
    Start of block
    End of block
    Blacklist...
    ReadConfig Blacklist
    Start of block
    YouNameIt
    End of block
    /bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/List.3224
    Sort...
    Choose packages...
    Choose DEPS...
    Choose SUPPKG...
    Create ZYPKG_INFO.tgz
    TarHeader
  • Mijzelf
    Whoops. That is a misconfiguration in the server. This should have failed, but it didn't. I'll inform the server admin tonight.
    As a work-around you can create a directory \\<NAS>\admin\MyRepo\ on your NAS, and put ZYPKGS and Tweaks_20200310_arm_035.zpkg (and other packages you'd like to install) in it, from http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/
  • artwich
    The Tweaks are here !!!
    @Mijzelf Thank you so much. I really appreciate it.
    Now, I will move on to the Tweaks and hope my hard disks will get some sleep !!
