Firmware Server down?
Hello all,
I try to setup three USGflex200HP in three different locations since yesterday. Are the servers down? Another problem? Anyone here who can provide the latest firmware file?
Thx,
Holger
Upon reviewing your case, we have determined that the issue is related to the certificate service and it has been resolved. Please refer to this forum thread:
Kay
Hi @Holger_AZ
Regarding your issue with updating the firmware through the cloud, it could be due to several reasons, such as internet connection issues or DNS query failures. To further investigate your problem, we need your help to manually upgrade your firmware to the latest version and then try the firmware upgrade via the cloud server again.
Please upgrade your firmware manually by clicking "Upload File" on the interface. To upgrade your USG FLEX 200H firewall to the latest firmware, you need to first upgrade to firmware version uOS 1.08 Patch 1, and then upgrade to uOS 1.20. You can find the detailed procedure for the firmware upgrade here:
I have sent you the firmware version 1.08 (ABWV.1)C0 via private message. Please check it out.
Kay
Kay
Hi Kay, I have the same error with a flex 500H. Can you send me please the firmware also?
I need it verry fast. Thank you.0 -
Hi @Memli
This issue could stem from various factors, such as internet connection problems or DNS query failures. Could you check if your site is experiencing these issues?
Additionally, could you share the current firmware version of your USG FLEX 500H firewall with us?
Kay
I have also this problem… Can I get this firmware fast please ! This new 200H is to replace a 200 that have this signature bug after the 24 of january ! No comment
Have you has a chance to check your internet connection and DNS setting to see if they might be causing issue with the firmware update?
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 354 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
