How to install a VPN server on NSA325-v2
  • Tomalamix
    Tomalamix Posts: 69 image  Ally Member
    I will check that.
    One more thing, I have a PC inside the network where the NAS is installed. Is possible to do send a wake on lan packet to that PC within the NSA325? Is it able to do such a thing as I am in the SSH session?
    Thank you!
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Yes. Provided you have the right binary. As far as I remember Entware has a binary for that. Etherwake,
  • Tomalamix
    how to use it? I dont know the command to do it.
  • Mijzelf
    Something like 'etherwake mac:address:of:pc'. If that fails, try 'etherwake help' or 'etherwake -h' or 'etherwake —help'.
  • Tomalamix
    i can find ethtool, is related with ethernet settings but I could not find any command for wake. I am logged in using the SSH by the way, I dont know If I have the same kind of access to have all commands available using this session.
  • Mijzelf
    Etherwake is an Entware-ng package. So you should first have installed Entware-ng (which can be done through MetaRepository) and then use Entware's package manager opkg to install etherwake.
  • Tomalamix
    lol.. well, I need to confess that I am a windows user and this thing of install packages under linux/unix or other is very far from my knowledge, I can run a few commands and thats it. Sorry :) How can I install it from the repository?
  • Mijzelf
    Assuming you already installed Entware-ng, you should
    su
    opkg update
    opkg install etherwake
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    According to this page…
    https://openwrt.org/docs/guide-user/perf_and_log/benchmark.openssl
    Best performances for a Marvell 88F6282 in SHA256 is 8.949.140
    Best performances for a Broadcom BCM2711 in SHA256 is 132.161.980
    Adding a VPN server on this NAS is really suboptimal for performances and can harm a lot the file transfers.
  • Tomalamix
    edited February 2025
    ok, is not working..
    ~ # opkg
    sh: opkg: not found
    probably because I dont have this:
    Entware-ng
    which I dont know how to install..
