HOTEL PMS with USG FLEX 700
ieur
we use USG FLEX 700 in our hotel with the tickets hotspot, how to connect it to our hotel PMS for automatic creation and printing of tickets based on the customer's name as user name, their room number as password and finally their duration hotel stay as the validity period of the ticket?
Sincerely
Hello sir
I understood the process well.
and how should I proceed to connect my PMS with the USG FLEX 700 API? knowing that our top-vision PMS from Topsys hotel management app, uses the FIAS IP protocolThanks
Hi @greg,
I'm not sure if there's an API or other method could connect your PMS and the USG FLEX 700. Let me check this for you.
Zyxel Melen0 -
ok thanks i am waiting
please urgent situtation
Hi @greg,
After checking with our engineer, the USG FLEX series doesn't have API to support this scenario. For a workaround, we suggest having an external Radius server for you to create/detele the WiFi client and its password. For this method, you will need to change the SSID authentication method from local to external Radius server.
Or, you can consider using our DPPSK feature(Pro pack feature), if your AP is Zyxel AP and it is a Nebula support model which supports DPPSK. The DPPSK feature supports API to create a DPPSK account and get the DPPSK key, but the password will be generated randomly.
Here are the DPPSK FAQs:
[NEBULA] How to use dynamic password for each client with DPPSK? — Zyxel Community
Where can I get the DPPSK API token on Nebula? — Zyxel Community
How to create a DPPSK key entry via Nebula DPPSK API? — Zyxel Community
How to get all DPPSK keys information via Nebula DPPSK API? — Zyxel Community
Hope it helps.
Zyxel Melen0 -
thanks to you for your answers
and how did do to setup external radius server with my flex 700 ,i have a synology nas with embled radius server?and i using unifi access point
No answers to my preoccupation since many months why?
Hi @greg
Sorry for the delayed reply.
Please reference these FAQs:
Does Nebula firewall support external authentication method? — Zyxel Community
Hope these helps.
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
