How to install a VPN server on NSA325-v2
First install MetaRepository, then you can install Entware-ng using the package manager.
I cant install the Metarepository..
It has moved, probably some time ago, to another URL and I cant install it. I access the NAS by FTP, place the file "web_prefix" inside this folder here because I cant find any other folder as described in the installation procedure:
/i-data/910115eb/admin/zy-pkgs/ - Here I put the "web_prefix" (no suffix, lower case and all that)
After I go retrieve packages but nothing, But I can go to the URL where the web_prefix points to and there is stuff there but the NAS doesnt retrieve the list.
When I access by FTP i dont have a folder called NSA325, I have tmp, etc, bin, lib and all that sort of Linux typical folders, the only place where I can access something with the structure "NSAxx\admin\zy-pkgs\" is in that folder I mentioned, maybe is not the right one ?
/i-data/910115eb/admin/zy-pkgs/ sounds alright. Did MR create a directory MetaRepository in it? If yes, there should be a logfile ZYPKG.tgz.log. Post that.
HandleZYPKG_INFO /NSA325-v2/4.80/zypkg
FindApp md5sum found /sbin/md5sum
ReadConfig Repositories
Start of block
ftp://ftp2.zyxel.com/+ ZyXEL
http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4/ Mijzelf-Old
/i-data/md0/admin/MyRepo/ Local
End of block
8 start: 12:25:00
9 start: 12:25:00
7 start: 12:25:00
8: FetchZYPKG_INFO http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4/ 8 Mijzelf-Old
9: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ 9 ZyXEL
7: FetchZYPKG_INFO /i-data/md0/admin/MyRepo/ 7 Local
8: FindApp curl found /usr/bin/curl
7: FindApp curl found /usr/bin/curl
9: FindApp curl found /usr/bin/curl
7: Fetch /i-data/md0/admin/MyRepo/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/i-data_md0_admin_MyRepo.tmp failed
7: Fetch /i-data/md0/admin/MyRepo/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/i-data_md0_admin_MyRepo.tmp failed
8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_.tmp failed
7: Failed
7 stop: 12:25:01
8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_.tmp failed
8: Failed
8 stop: 12:25:01
9: Fetch ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NSA325-v2_4.80_zypkg_.tmp failed
9: Fetch ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NSA325-v2_4.80_zypkg_.tmp failed
9: Failed
9 stop: 12:25:03
Pushlist...
ReadConfig Pushlist
Start of block
End of block
Blacklist...
ReadConfig Blacklist
Start of block
YouNameIt
End of block
/bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/List.3291
Sort...
Choose packages...
Choose DEPS...
Create ZYPKG_INFO.tgz
TarHeader
Fetch /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz - succeeded0 -
zyxel.diskstation.eu is no more. You have to change that to zyxel.ddnss.eu in the webinterface of MetaRepository.
Ok, it is done, now the list is populated and I installed the Entware.
I go to the management page but the packages list is empty so I cant select nothing from there to install. Should I retrieve or update the packages list manually somehow?
I used the "opkg update" as SU to update, it updates but the list remains empty
I had forgotten about the webinterface of the Entware-ng package. As far as I remember it shows the contents of the package server. Don't know why it's empty for you, maybe the URL changed when repo was archived.
Anyway, it has no direct relation to what is installed on your box. You can install a package with
su opkg install <packagename>
you can list available packages with
opkg list
There is also an option to see which packages are installed, 'opkg list —installed', maybe, but 'opkg help' can tell.
A lonnngg list of stuff. Ok, i manage to find it but when I run the install command it replies me that is up to date? so is installed but I cant use it?
~ # opkg install entware-opt
Package entware-opt (222108-5) installed in root is up to date.0 -
Now you lost me. You wanted etherwake, then why install entware-opt?
lool..you are absolutely right, I dont know why I had entware-opt in my head.
Now etherwake is installed, now i need to be sure that the PC is ready to receive the WOL packet. THe usage is simple, with MAC address. Thanks for all inputs!
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
