Packages for NSA320
Yes, it's an old model, but it works fine so I'm reluctant to bin a working unit. However, I would really like the Google Sync package, but it won't install from the admin. I guess Zyxel stopped making the software available. I can understand not issuing firmware updates, but why take these offline? Guess they want to force people to buy more hardware.
Is there somewhere else I can download these packages? If I don't download/install via the admin, how do I install it (if the download is available)?
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    ZyXEL have decided to pull the packages for the NSA series from their package server. I have backups here:
    To install them, install MetaRepository, and exchange the stock repository as described here.
    Having said that, I doubt the Google Sync package will still work. It hasn't been maintained for years, and cloud services are evolving fast.
  • Thanks, Mijzelf. I did see a post from, I think, November last year where someone was complaining about Google Sync not working. A Zyxel tech said, "they were working on it". Guess that's code, for, "Screw you buddy!!!"
    I accomplished what I needed with an auto backup program I used last night. It's called AutoVer - a brilliant program (and free!!). You set it to "watch" folders or files and every time it sees a change, it automatically backs the file or folder up. I've been using it for years. I needed backups of my websites copied to my NAS. The backup extension on the websites saves them to Google Drive, so I just set up a Google Drive folder on my computer and has AutoVer backup that folder to the NAS. Simple and worked perfectly.
  • kekxlsske2
    kekxlsske2 Posts: 1 image  Freshman Member
    Hi, @Mijzelf , the repositories under https://zyxel.diskstation.eu are not reachable anymore. Did you move them?
  • Mijzelf
    Did you move them?
    No. But the domain provider stopped, so now there is a new domain: zyxel.ddnss.eu
