NR7101 V1.00(ABUV.11)CO
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
  • Mayone78
    Mayone78 Posts: 46 image  Freshman Member
    First Comment Friend Collector Second Anniversary Community MVP
    update to ABUV11 the NR7101 disconnected from LTE/5G. No way to make it working again.
    Revert to V10.
  • SmileitsMe
    SmileitsMe Posts: 11 image  Freshman Member
    Hi! Have running the ABUV.11 with
    RG502QEAACR13A05M4G_ZYXEL
    the Modem firmware has been provided by A1 in Austria via Update . But is also running with Hutchinson DREI here in AT.
    Can somebody provide the modem Update file RG502QEAACR13A05M4G ? or ist this A1 only
  • SELBERG
    Zyxel named their latest official firmware RG502QEAACR13A04M4G_ZYXEL but earlier firmwares QEAAAR.
    Official firmware can´t autoupdate or download from GUI, you need first to download separately from their official page and then update modem in GUI with the ZIP-File.
    https://support.zyxel.eu/hc/en-us/articles/4403365084818-Zyxel-5G-Devices-NR-Series-Advanced-Downloads-Firmware-and-other-resources#h_01J7ZRPS4WKP2D0F6D46MPAEQ3
  • DOES
    DOES Posts: 6 image  Freshman Member
    I have two NR7101 on V.11 with the following module firmware RG502QEAACR13A03M4G_Zyxel and RG502QEAAAR13A03M4G_BETA_ZYXEL_20240522A. Apparently no upgrade path, as they require A02 or A04 module - attempts to use any of the published files result in «illegal image» error… any ideas?
  • DOES
    should mention that DFOTA fails as well…
  • SELBERG
    Where did you download that firmware?
  • DOES
    Second hand purchase so no idea…
  • mariosfx
    mariosfx Posts: 4 image  Freshman Member
    hi, i am on
    and no internet. tried everything! any help how to downgrade or upgrade to make it work?
  • caligula
    caligula Posts: 6 image  Freshman Member
    Note that it seems this version blocks in the modem configuration (AT commands) the REGION in which it is supposed to operate i.e. it doesn't respect the "Data Roaming" setting from the webgui, but instead gets stuck in some region (which might be Austria given this firmware comes from an operator), hence likely refuses to operate in your country. Only option seems, anytime the zyxel reboots, to go in the WAN settings, disable roaming, apply settings, wait, re-enable roaming, apply settings, wait, and then it should be good. Or go back to v10.
