[NEBULA] Captive Portal Functionality
So, my path to access internet would be - User connects to WiFi → Splash Page w/ email field auto opens → MailChimp API Script → Allow user access to internet (i.e. unlock their IP) → Go to our main website.
How can I do this?
Hi @zenadmin,
I think you can build up a external captive portal web server for this requirement.
We provide the captiva portal html file to our users. You can edit the "click_to_continue.html" to have a column to enter the email address and add additional function when click the "Agree" button. You may write your own function to make the server sent the email address to your email, or you can store it in anyplace.
Here are some FAQs to set the external captive portal:
How to configure external captive portal — Zyxel Community
[Nebula] How to configure external captive portal for a SSID? — Zyxel Community
Hope these helps.
Zyxel Melen0
Hi @Drew
Are you perhaps using an external captive portal and using MailChimp to mine the email addresses there?
Is there a reason why you can't gather the email addresses from the Nebula platform's frontend?
This should be possible if you set the NAP's captive portal to Nebula Authentication Server and allow users to create auto authorized accounts.
Proceed to ORGANIZATION > Configure > Cloud authentication > Guest and the emails should now be saved there.
Regards,
Barney Gregorio0 -
If I went this route, it would require users to create/manage accounts. We don't want that. We just want a simple email field w/ a submit button. Our goal is to be as unobtrusive as possible.0
What about using sign-on with Facebook accounts?
You should be able to gather the email accounts using the email summary report.0 -
No, still don't want any sort of sign in requirement. We just want to capture email. I'll figure out another way. Thanks all for the input so far.0
Would love to know if anyone figured this out….
Hi @zenadmin,
Hope these helps.
Zyxel Melen0 -
Hey all — jumping in here as this is exactly the use case we’ve been working on.
We recently launched a new external captive portal integration for Zyxel Nebula that solves this exact flow:
- Guest connects to WiFi
- Simple branded page with email field appears (no account creation or social login required)
- Email is captured and synced to tools like Mailchimp, Klaviyo, or HubSpot
- Guest is instantly redirected to your homepage or desired landing page
No need for users to create accounts or manage credentials. It’s designed to be quick, clean, and unobtrusive — ideal for hospitality, retail, or events.
If you want to see how it works, here’s the info:
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
