New WAN status missing gateway IP for VLAN
PeterUK
PeterUK Posts: 4,448 image  Guru Member
edited October 2024 in Nebula
VLAN443 is what the FLEX H will use to talk to your server their should be a gateway 192.168.44.2
  • Zyxel_Kay
    Hi @PeterUK
    Could you please enable HTTPS WAN access on your USG FLEX 200H for remote access? Additionally, kindly activate Zyxel Support access on Nebula Control Center and share your Nebula organization and site name. We need this to gather more information for our investigation.
    Once everything is set up, please send the device GUI login credentials to us via private message. Thank you for your cooperation!
    Kay
    PM sent
  • Zyxel_Kay
    Hi @PeterUK
    Apologies for the delayed response.
    This issue is connected to a known issue, ZNGA-6154. We're currently working on a fix, which is expected to be included in the next official firmware release at the beginning of 2025.
    For more information on firmware version uOS1.30, please refer to the release notes here:
    uOS1.30 Release Note
    Kay
    edited February 2025
    I can now see gateway IP's for VLANs👍️
Nebula Tips & Tricks
