ATP 500 - Random Reboot
Best Answers
I waited a few days and kept a close eye on the ATP500.
To date I can say that it has not rebooted after five days.
Thank you for your prompt reply, for finding the problem and for providing me with the solution.
I am truly satisfied.
Thank you againD.
Update:
This issue is fixed by weekly firmware, and it will be included in the next firmware release.
Zyxel Melen0
Update ...
I downloaded the Debug file (as indicated)and checking the file diag_zysh_system.dbg there are many occurrences :
Reason: <Continue> Fatal Error Causes System Reboot
What do they mean?
My thanks and greetingsD.
Excuse me, but is there no one from Zyxel?
The equipment is becoming unserviceable. It reboots all the time. Even right now it has rebooted with almost no traffic.
I am seriously thinking of buying something else and giving up on Zyxel with its ‘negative publicity’.
Is it not possible to get to the cause ?Regards
D.
Hi @Ceccus,
I will send you a private message to request the debug file. Our engineer will check the debug file to find the root cause. Please check your private message box.
Zyxel Melen0 -
Thank you for your reply.
File attached to private message.
I await your reply.
Kind regardsD.
Thank you againD.
Update:
Zyxel Melen0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
