ATP 500 - Random Reboot
Ceccus
Ceccus Posts: 46  Freshman Member
edited March 16 in Security
My ATP 500 frequently restarts several times a day. Apparently for no reason.
From the System Log you can clearly see it.
Of course, each time the network is interrupted for 3-5 minutes.
Any idea what the reason is?
D.
Best Answers
  • Ceccus
    I waited a few days and kept a close eye on the ATP500.
    To date I can say that it has not rebooted after five days.
    Thank you for your prompt reply, for finding the problem and for providing me with the solution.
    I am truly satisfied.
    Thank you again
    D.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,810  Guru Member
    Update:
    This issue is fixed by weekly firmware, and it will be included in the next firmware release.
    Zyxel Melen
  • Ceccus
    edited March 16
    Update ...
    I downloaded the Debug file (as indicated)
    and checking the file diag_zysh_system.dbg there are many occurrences :
    Reason: <Continue> Fatal Error Causes System Reboot
    What do they mean?
    My thanks and greetings
    D.
  • Ceccus
    Excuse me, but is there no one from Zyxel?
    The equipment is becoming unserviceable. It reboots all the time. Even right now it has rebooted with almost no traffic.
    I am seriously thinking of buying something else and giving up on Zyxel with its ‘negative publicity’.
    Is it not possible to get to the cause ?
    Regards
    D.
  • Zyxel_Melen
    edited March 17
    Hi @Ceccus,
    I will send you a private message to request the debug file. Our engineer will check the debug file to find the root cause. Please check your private message box.
    Zyxel Melen
  • Ceccus
    Thank you for your reply.
    File attached to private message.
    I await your reply.
    Kind regards
    D.
  • Ceccus
    Thank you again
    D.
  • Zyxel_Melen
    Update:
    Zyxel Melen
