FWA710 dropping 5G and returning to 4G.
Noddy
Noddy Posts: 67 image  Ally Member
First Comment First Answer Friend Collector Third Anniversary
Hi all,
An annoying issue that has started in the last few days. I don't think it is a router issue, and I have also raised a ticket with EE about this. But thought I'd ask the question here also in case their is a known bug?
Using latest firmware for awhile now.
But this is what I'm seeing, randomly it returns to 4G (LTE-A):
I can either choose to reboot the router (hence the low uptime shown above) or, toggle the "access technology" to something that I don't get, like 5G-SA which forces a disconnect, then I change back to 5G-SA/5G-NSA/4G (Auto) to reconnect.
On reconnect, I get 5G:
My signal strength is pretty much OK.
RSSI -72 (Good)
RSRP -83 (Good)
RSRQ -11 (Good)
SINR 3 (Fair)
SINR could be better but I am 4KM away from the tower but I get decent ping and speeds.
So yeah, any ideas? As I'm stumped. 😁
Thanks.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @Noddy,
    This issue should be less related to the firmware. Additionally, you may feel free to share the ISP's feedback with us.
    Zyxel Melen
  • Noddy
    Thanks @Zyxel_Melen . When I logged a fault via the app with EE they said there were no issues. I've yet to call to take it further. Current workaround is to take the Cell and RFCN ID's and to add a 4G Lock. It drops randomly, but, reconnects with 5G again. So no more worrying about dropping back to 4G. But no fix, as of yet.
  • Noddy
    I also plan to do a power down of all kit this weekend, to see if that helps.
  • Noddy
    edited April 2025
    @Zyxel_Melen unfortunately this doesn't appear to be an ISP issue. I'm trying a Vodafone SIM at the moment, 5G has good stats according to Router and Zyxel Air app. Yet Router has been up for just 3 hours and in that time it has gone back to 4G. That's two different ISP providers and two different masts / cells. What gives? Here are some stats after I toggle the wan from 5G-SA back to 5G-NSA/4G.
  • Noddy
    Just a quick update. Hoping that after speaking with Zyxel support (who have raised a feature request for me) that we can get an additional drop-down in the band selection menu, so that we can choose "5G-SA/5G-NSA" without a 4G option. The idea being if this disconnect happens it can't fall back to 4G and hopefully would just re-connect again with 5G. I've performed a factory reset of the FWA710 and I'm monitoring how that goes as well.
  • Noddy
    Also interesting that others have similar problem all of a sudden…
    FWA710 losing 5G — Zyxel Community
