Trying to setup Multy Plus using WebGUI - unable to access myZyxelCloud
I have Multy Plus WSQ60 Wifi Router.
I am trying to setup the router via the Web GUI.
The router was previously used by someone else, so I reset it before starting the setup process. The setup goes smoothly until I have to access the myZyxelCloud, which does not work.
When I click "Next" to access the cloud, the GUI tries to connect for a bit, then a warning message appears which says: We have some problems, reload the site or try again later.
When I try again later, it still does not work.
I tried resetting the router a second (and third) time with the same result. I tried using different browsers (Firefox and Chrome) with the same result.
The internet connection does work, the WLAN I set up works as well, but I cannot access myZyxelCloud and finish the setup process.
I only want to use the Web GUI, not the app.
any ideas?
Hi @copossum,
To help you fix this issue, I will send you a private message to book a remote. Out engineer will help you during the remote.
Zyxel Melen0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
