SecuExtender VPN Client
PaoloArlotti
PaoloArlotti Posts: 2  Freshman Member
Sixth Anniversary Nebula Gratitude
I configured a USG FLEX 100 firewall in Nebula mode, activated the IKEv2 VPN, and exported the configuration file.
When I try to import the configuration file into my subscription-based SecuExtender VPN client, the message 'Error loading VPN configuration file' appears.
I have no further logs or warnings. I searched for instructions on the internet, but without success. How can I resolve this?"
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @PaoloArlotti,
    Please help check that you're using the latest version.
    And import the correct file.
    Please enable Zyxel support access if the issue remains. We will download the file from your site and check if there is any problem.
    P.S. In our test, the import configuration is working without any issue.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PaoloArlotti,
    Zyxel Melen
Nebula Tips & Tricks
