NWA130BE: cannot connect to 6ghz
Hi @chatziko,
Regarding the XPS9315 can't connect issue, I can find a key handshake fail issue in the event log. I'm checking with our engineer, and I will keep you posted.
About the Pixel 7a, I found some issues with the 6 GHz SSID on another forum. (link) Could you help with a test on the Pixel 7a?
- Please download WiFi Analyzer.
- Open WiFi Analyzer and set a filter with 6 GHz only.
- Check the Access Points tab to see if you can see the 6 GHz SSID.
Zyxel Melen0 -
Hi @chatziko,
I have sent you a private message. Please check when you are free. Thanks~
Zyxel Melen0 -
Hi @chatziko,
Since the XPS9315 encounters the key handshake fail issue, please reference this FAQ to troubleshoot first.
Zyxel Melen0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
