NAS540 web interface unavailable after firmware update
kimme
kimme Posts: 38 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
A couple of weeks ago I've updated my NAS540. As I could access my drives there didn't seem to be an issue.
However today I tried to login to the webinterface which stated that my login credentials were wrong (I know for sure they aren't).
I tried resetting the credentials using the reset button at the back, sadly without success.
SSH also doesn't work.
Drives are accessible.
Any idea's on how to fix this?
  • skynet2001
    skynet2001 Posts: 10 image  Freshman Member
    Same for me also looking for a solution
  • Hopoick
    Hopoick Posts: 1 image  Freshman Member
    Ensure you're accessing the correct IP address for the NAS. Sometimes, after an update, the IP address may change.
    If you have a monitor and keyboard connected to the NAS, check if the NAS shows any error messages on the screen that could provide a clue about the issue.
    Hope this help.
  • gyulav
    gyulav Posts: 10 image  Freshman Member
    Try this in web browser:
    https://nas540.local or http://nas540.local
  • kimme
    IP is correct, NAS is headless in technical room so no possibility to connect monitor/keyboard
    It connects to the NAS but I still can't log in. Everytime I try to I'm getting an email as wel for logging in with wrong credentials.
  • Mijzelf
    Mijzelf Posts: 3,050 image  Guru Member
    You did reset the credentials. You are aware that then you should login as admin/1234?
    Have you tried another browser?
    When everything else fails, only a full factory reset remains. That won't delete your data, although you'll have to re-enable all custom shares.
  • kimme
    Yes I am aware of that. It doesn’t work.
    Tried other browsers as well.
    I’m really hesitant to do a full reset. You never know. I’ve lost all my data once in the past, won’t want to risk it again.
  • Mijzelf
    A factory reset only erases a partition on the internal flash. It doesn't touch the disks.
    But if you are really concerned about your data, you should have a backup. The NAS or the disks will fail, some day.
