Timeout error creating captive portal user with NCAS on NWA90AX access point
maxpontello
maxpontello Posts: 3
image  Freshman Member
i'm experimenting issues testing NCAS (Nebula Cloud authentication) with captive portal on a NWA90AX access point. When i connect to the network, which is password protected using WPA3, the system correctly addresses me to the NCAS login page. I choose to register a new user, fill in all the required fields and when i press ok i receive a timeout error after a while. I attach my captive portal config and a shot of the error shown on a mobile phone. I've opened a service ticket to Zyxel support 20 days ago but they can't solve my issue until now and now they disappeared… (ticket #501972)
Any help is appreciated, thanks!
Max
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,220
    image  Zyxel Employee
    edited May 2025 Answer ✓
    Hi @maxpontello,
    I did a quick local test with your configuration but I created the account with success. We will try to add our AP to your site to reproduce this issue. Also, could you help to check if your uplink router/firewall blocks https://ccapi.nebula.zyxel.com?
    Update:
    Add AP to your site also created the account with success. In addition, I found your firmware version is not latest, could you also try upgrade to latest firmware version?
    Zyxel Melen
  • Zyxel_Melen
    Hi @maxpontello,
    Could you help to enable Zyxel support access? So we can copy your configuration and reproduce it in our lab.
    Zyxel Melen
  • maxpontello
    Hello @Zyxel_Melen, thanks for your answer. Zyxel support access is enabled.
    Looking forward your help.
    Bye
  • Zyxel_Melen
    Hi @maxpontello,
    Update:
    Zyxel Melen
  • maxpontello
    Hello @Zyxel_Melen,
    i've tried upgrading the APs to the latest firmware versions and magically everything now is working.
    I've not upgraded before and kept last stable version because usually i prefer to avoid possibile bugs introduced by not stable versions. Is it correct that NCAS system works only with latest versions?
    Anyway, thanks! Your support was really appreciated.
    Max
Nebula Tips & Tricks
