How to resolve the Zyxel FWA7100 IP from internal network
I've a Zyxel FWA 710 that is configured in bridged mode, then a FritzBox 7590AX that's used to connect home devices, DECT and so on.
The issue I've is that every time I need to connect to the route I've to do something as
C:\Users\paolo>tracert www.google.com
Tracing route to www.google.com [216.58.204.228]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms fritz.box [192.168.1.1]
2 2 ms 1 ms <1 ms 151.59.109.176
3 * * * Request timed out.
4 22 ms 20 ms 23 ms 10.75.13.170
5 61 ms 16 ms 19 ms 151.7.80.14
6 52 ms 19 ms 19 ms milo-b02-miot-t02-ge1-1.wind.it [151.6.7.42]
7 34 ms 28 ms 18 ms 151.6.7.181
8 28 ms 31 ms 28 ms 74.125.32.80
9 57 ms 24 ms 30 ms 209.85.254.219
10 23 ms 19 ms 20 ms 192.178.82.63
11 48 ms 18 ms 19 ms par21s06-in-f228.1e100.net [216.58.204.228]
Then in this case get the 151.59.109.176
and connect to it.
Can I add a DNS header as fritz.box so I can just connect to it?
Paolo
Hi @advapiIT,
Sorry for the delayed reply. Based on your description, your FWA710 is more likely in router mode, not IP passthrough mode/bridge mode. The reason is that you mentioned "the FritzBox is set as main router on 192.168.1.100". FWA710 router mode has a DHCP server with pool 192.168.1.X. Therefore, please change your FritzBox LAN DHCP server setting to fix the IP conflict issue, and then you may access FWA710 with 192.168.1.1.
The previous FAQ is the method for accessing it if you want to change to IP passthrough mode/bridge mode.
Zyxel Melen0
Hi @advapiIT,
You can access FWA710 from internal when it is under bridge mode is normal behavior.
You can check the IP address of FWA710 on Nebula device detailed information page. If you want to set domain name for FWA710, you may use DDNS function for this requirement.
Additionally, to access the FWA710 in IP-passthrough mode, please reference this FAQ:
[Mobile router] How to access the local GUI in IP passthrough mode? — Zyxel Community
Hope it helps.
Zyxel Melen0 -
Hello, I've checked your suggestion but in my case the FritzBox is set as main router on 192.168.1.100… I've already a DDNS but using it it give me the ip prior of 1 number, I need to ping the DDNS then add another number to that list to have the IP…
it's not possible in bridge mode to add a dns suffix?
Hi @advapiIT,
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
