Activate SNMP on NR7302?
max93776
Hi, is there a way to activate snmp on nr7302? There is no option in the webui but zysh shows that there is a setting.. zysh is too buggy though. A simple snmpwalk showed no reaction
SNMP ist not installed. You would have to gain root and install the package/add the binary.
seems to expose SNMP settings, but it’s buggy. shows no response, meaning SNMP is probably disabled. Cat Meow Sounds
How can I get root access, I know that some older routers it was possible to calculate it with serial number
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
