Issue Pushing Flex 200 Firmware Updates
Pook
Pook Posts: 151  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
Anyone else having issues pushing out Firmware Upgrades? Tried on Multiple Orgs and appliances I manage and the firewalls do not respond to the commands.
  • RasnoDigl
    RasnoDigl Posts: 16  Freshman Member
    Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Administrator - Nebula First Comment Seventh Anniversary
    Hi Pook, I don't know if your problem is like mine: after the firmware update the switches were no longer seen by NCC, even if they worked correctly on the internet; so I could no longer manage them from NCC and therefore they could not be controlled remotely; If this is your problem, the great Engineer Chris from Zyxel solved the problem for me, making me add a line in the NCC Dashboard, precisely in configure-> securitygateway-> gateway settings-> in DNS address record; If this was your problem, I would be very happy to share the line to add; If your problem is different from this, I'm sorry, but I can't do anything else. Have a good day, good work. Andrea
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,714  Zyxel Employee
    Hi @Pook,
    Could you help to enable Zyxel support access for these organizations so we can help to check?
    I will send you a private message for the orgnization list. Thanks~
    Zyxel Melen
  • Zyxel_Melen
    Hi @RasnoDigl,
    I assume this is a different case from yours since your issue was on the switch. However, the pook's case is that the firewall didn't perform a firmware upgrade after being triggered.
    P.S. I will let Chris know your feedback.😁
    Zyxel Melen
  • RasnoDigl
    Thanks Melen, I really appreciate you, you are a fabulous technical support. Andrea
  • Pook
    Thanks for the replies. I tried again today and it is working now so most likely a browser issue on my end. Thanks again, this is a great community :-)
  • Zyxel_Melen
    Hi @Pook,
    Thanks for you update!
    Zyxel Melen
Nebula Tips & Tricks
