Captive Portal & Zyxel Nebula
Is anyone using a third-party captive portal system alongside Nebula?
We want to capture name, email address and marketing consent for anyone connecting to our guest wifi and I don't believe the built-in captive portal has this capability.
Hi @nickpatchett,
Regarding the captive portal capability you required, Zyxel Nebula does support this functionality, such as name and email address. The following tutorial shows you how to configure captive portal settings for an SSID profile.
- Go to Site-wide > Configure > Access points > SSID settings
- Click on Advanced mode switch, Add SSID network, and Edit to edit your SSID profile
- Go to Site-wide > Configure > Access points > SSID advanced settings to assign an SSID Name and enable the SSID. Next, select the Sign-on with: Nebula cloud authentication to use the NCC user database to authenticate users.
- If you select My RADIUS server, enter the RADIUS server’s Host, Port, and Secret. Enter the Network Access Server (NAS) identifier on the Nebula Device to identify the Nebula Device to the RADIUS server, if required. This might be necessary if there are multiple Nebula Devices behind NAT using the same public WAN IP address for the RADIUS server. Note: Make sure to add the Nebula Device (AP) to the trusted device list in the RADIUS server.
- Scroll down the page to choose your Self-registration method. Then click Back and Save.
- Create a Custom Captive Portal Page by going to Site-wide > Configure > Access points > Captive portal customization.
- On the original page, there is only a default theme to choose from. To design your own theme, click on the copy icon, and then the ‘Copy of Modern’ will appear on the right. Then click the edit icon to customize your captive portal page. Alternatively, use an external captive portal URL if necessary.
- Click on the icon on the right of ‘Copy of Modern’ to modify your theme name. You might also need to edit the HTML and CSS code to capture users’ names and email addresses. Please refer to the information in this FAQ link for steps on this part.
- To check users’ names and email addresses, go to Site-wide > Configure > Cloud authentication to confirm that the information displays correctly.
Regarding the marketing consent, could you please provide more details on how you would like to collect this information from users? This requirement may need additional effort in editing the HTML and CSS sections.
Zyxel Tina
Hi @nickpatchett,
Zyxel Tina
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
