Wireless Clients shown wired
Oliver_Fehn
Oliver_Fehn Posts: 11  Freshman Member
after restarting all devices, the display of wireless and wired clients fits.
After a certain time, wireless clients are then displayed as wired. Just a restart of the accesspoints fixes the problem for a short time. Does anyone have a similar problem and can help me.
My devices are
USG lite 60
2 x GS1915
3 x NWA90AX Pro
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,741  Zyxel Employee
    Hi @Oliver_Fehn,
    After investigation, we have addressed this issue because specific AP model, NWA50AX PRO and NWA90AX PRO, updates the info to Nebula with errors. This issue will be fixed in the next firmware release, around July. Please check the wireless News and Release - Zyxel Community category for new updates~
    Zyxel Melen
«1
  • Zyxel_Melen
    Hi @Oliver_Fehn,
    Could you share the real topology and enable Zyxel support access so I can check the Nebula topology?
    Zyxel Melen
  • Oliver_Fehn
    Hi @Zyxel_Melen, i have now activated support access
  • Zyxel_Melen
    Hi @Oliver_Fehn,
    Thanks for the privilege. I found one of your device displayed as weired device, one of Apple home pod. We are investigating this issue and I will keep you posted.
    Zyxel Melen
  • Oliver_Fehn
    edited May 21
    Hi @Zyxel_Melen,
    there are several more devices that are connected wireless that shown wired, there are
    Sweeper, Meross Smart Switch, Siemens, Nuki Bridge, Echo and so forth.
    Could it be due to the firmware version of the switches? They're not running the stable version, but the latest one.
    Sincerely
  • Oliver_Fehn
    edited May 25
    Hi @Zyxel_Melen ,
    I tried a few things over the weekend and think I've solved the problem.
    I did the following:
    I completely removed the Fritz!Box from the network.
    In Smartmesh, I set the uplink of the wirelessly connected access point to manual uplink and selected an access point.
    Since making these changes, the problem hasn't occurred again.
    Sincerely
  • Oliver_Fehn
    edited May 27
    Hi @Zyxel_Melen
    it's been working fine for two days now, but now a wireless client is showing as wired again.
    At least it's a bit better now, as previously several clients were showing incorrectly within a day.
  • Zyxel_Melen
    Hi @Oliver_Fehn,
    Thank your for updating your test and its result.
    After discussing with our engineer, we assume this is because the client list update mechanism causes the client type to change. We are still investigating on this and I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Oliver_Fehn,
    Zyxel Melen
  • Oliver_Fehn
    Hi @Zyxel_Melen,
    thank you for your efforts.
  • Oliver_Fehn
    Hi @Zyxel_Melen,
    unfortunately, even after the update, the problem persists. After a while, some wireless clients are again displayed as wired.
Nebula Tips & Tricks
