NWA130BE: cannot connect to 6ghz
Hi @chatziko,
Regarding the XPS9315 can't connect issue, I can find a key handshake fail issue in the event log. I'm checking with our engineer, and I will keep you posted.
About the Pixel 7a, I found some issues with the 6 GHz SSID on another forum. (link) Could you help with a test on the Pixel 7a?
- Please download WiFi Analyzer.
- Open WiFi Analyzer and set a filter with 6 GHz only.
- Check the Access Points tab to see if you can see the 6 GHz SSID.
Zyxel Melen0 -
Hi @chatziko,
I have sent you a private message. Please check when you are free. Thanks~
Zyxel Melen0 -
Hi @chatziko,
Since the XPS9315 encounters the key handshake fail issue, please reference this FAQ to troubleshoot first.
Zyxel Melen0 -
EDIT: issue was using a 12V/1A adapter instead of required 12V/2A, works fine now.
Hello, i am having similar issues with NWA130BE, tried everythingZyxel_Melensuggested and more but unfortunately nothing solved the issue.
2.4 GHz and 5GHz work fine, to 6GHz clients cannot connect, always fails at getting ip address with error log:
deauthenticated by key handshake fail [count=2]
blocked by key handshake fail on Channel: 37, SSID: ZyxelNet, 6GHz, Signal: -54dBm, Download/Upload: 971Bytes/269Bytes, reason 15, Interface: wlan-3-1
reason 15 stands for 4-Way Handshake timeout
i tried:
testing with good connection (-35dbm)
latest firmware update
factory reset (several)
standalone manual configuration
online nebula configuration
changing channel width (80/160/320 MHz)
completely turning off 2.4 and 5 ghz
turning on Avoid 5G DFS channel
raising minimal WLAN Rate
switching 802.11be to 802.11ax and back for 6GHz
turning off authentication
and other things i cant even remember now
however, to no avail.
I have tested with 4 different devices, all released within last 2 years, all support 802.11ax and at least two i am certain support 802.11be.
I am very inclined to think this is some sort of a firmware issue or perhaps an issue with 802.11be itself, latest firmware was released over 4 months ago so i am not very hopeful for a fix but i wanted to inform other people who might be in the same situation. I will wait for a few days for some sort of support and if unsuccessful, will be returning the product.0 -
Hi @Martyno
Thanks for let me know this. Could you help to provide some detailed information to me?
- Is your NWA130BE running in standalone mode or Nebula mode? If is Nebula mode, could you help to enable Zyxel support access?
- How many Zyxel AP do you have and which model are they?
- Please try connect again so we can have the relative logs to check this issue.
- Here is the method to collect the diagnostic file. Please provide it to me via private message. Standalone mode / Nebula mode
Zyxel Melen0 -
The issue was on my end, I was using a 12V/1A adapter but after checking everything again i noticed the AP required power is 12V/2A. Now that i switched it everything seems to work fine, 6GHz immediately connects. Thank you.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
