Wireless SSID not visable
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Yesterday i had an strange thing. i have 3 wifi networks. but i just can find 1 (on both laptop as phone). all networks are enabled, and offcourse not hidden SSID. I didn't have time to investigate it yet, but i see this in the logging:
2 ports control blocks? what does this mean?
Can it has something to do with it?
I will investigate it later further.
  • Zyxel_Tina
    Zyxel_Tina Posts: 699 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Dpj,
    Thanks for sharing the log.
    The message ZDP: initial port [number] control block indicates that the Zyxel Device Protocol is initializing the control process for a network port. You may refer to this FAQ for more details on what this log means.
    As for your issue with only 1 SSID being visible (while all 3 should be), we also recommend checking this FAQ as well to help troubleshoot and resolve the problem.
    Zyxel Tina
  • Dpj
    Thank you Tina, Yes i think it had to to with the time schedules. Not completely sure, but now they are sending
Nebula Tips & Tricks
