Failover back on FWA510 fails
Zilversurfaren
Zilversurfaren Posts: 3 image  Freshman Member
Hi!
Using a FWA510 running firmware V1.18(ACGD.5)CO. Primary WAN is Ethernet (fiber) and secondary WAN Cellular (SIM card). When primary fails secondary kicks in and works nicely. However, when primary returns the secondary fails to go back, and is stuck until I reboot. Any ideas?
Thanks.
Zilversurfaren
    PeterUK Posts: 4,426 image  Guru Member
    edited July 2025 Answer ✓
    You need to enable this
    However there is a problem with it it seems due to the way it check ping out Ethernet which I will post about but I have another way of doing failover.
    So heres what happens ping to 8.8.8.8 is fine you go out Ethernet then ping fails and you go out Cellular then when ping is successful again you go out ethernet all seems good right? well no
    So in short what the connection check is set too forces all traffic that was going out Cellular to test Ethernet and will check for the number of check fail limit then if on reply to ping goes back to Cellular meaning their is a interruption as ping checks out ethernet so the only bad workaround is set connection check high and check fail limit low.
  • Zilversurfaren
    Thanks PeterUK.
    I do have the WAN Backup enabled, but will check your suggestion with a high interval and low fail limit.
  • Zilversurfaren
    Awesome PeterUK. Your suggestion with interval 60 and fail limit 1 did solve my issue. Can go back and forth between ethernet and cellular now. Many thanks!
    edited July 2025
    I posted a case with support to see about the problem I found.
    What I found that happens is every interval check (60 secs) by fail limit (1 sec) there is a 5 secs move from Cellular to Ethernet even if Ethernet is down by my checking which is Ethernet up and ARP is up but ping fails.
    But if Ethernet is up and ping ok all is fine its just the fail over of ethernet that's the problem
