Format of NAS325 drives
agmi
agmi Posts: 2 image  Freshman Member
edited July 2025 in Personal Cloud Storage
After removing the drives can I format them in Windows environment instead of using telnet (saw a previous post) and wait ages? The intention is to use them in a another NAS from another brand/make.
Best Answers
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Yes, you can. But you'd better just put them in the other NAS. It will have to format them anyway.
  • Mijzelf
    Depends. The hardware is good, although not very powerful by today's standards. The firmware has never been very good, and is quite outdated. Yet, if the firmware works for you, it works.
    If you want to update the firmware, that can be done by installing either Debian or OpenWrt. That's not extremely difficult, and yields to a small, up-to-date Linux server. But still not very powerful.
  • Mijzelf
  • agmi
    Dank u wel. One more quick question. Is there any future a barely used for NSA 325v2?
  • Mijzelf
