WBE660s fail to update the firmware 7.10 to 7.20
Happy owner of a WBE600s AP, it is impossible to update the firmware to its latest version!
In add, I noticed on the forum that some users were having difficulties with version 7.20.When is it? Should I wait for a new patch?Why can't I install 7.20?
Thanks in advance for your answers.
I have ignored the update as I have to many old devices which not have WPA 3 - so far have no problem with continuing using firmware 7.2.
I have one WBE 660 and 6 NWA 130 in my network.
For example some older iPad Pro do not have WPA 3 and as well temperature measuring devices.1
For example some older iPad Pro do not have WPA 3 and as well temperature measuring devices.1 -
Hi @DGOM,
Regarding the firmware upgrade, you can try the following official methods:
- How to upgrade the firmware for AP via Web Configuration
- How to upgrade firmware to the controller access point by FTP
- How to upgrade firmware by ZON utility
If the issue still occurs after trying these methods, we’ll need a bit more detail to understand what’s happening on your side. Please send us the following via private message so we can investigate further:
- Your network topology when doing firmware upgrade.
- Any error messages you encountered during the failed update (screenshots are welcome).
- A full video recording of the entire firmware upgrade process, so we can clearly see what happens.
- Diagnostic information exported from the local GUI. Please refer to this FAQ.
With this information, we’ll be able to assist you more effectively.
Zyxel Tina
I have some old devices, so should I keep the current version? It's strange not to ensure backward compatibility for the protocols in the new version of the firmware, right?
To update this Wi-Fi access point over the web, do I need to open a specific port on the router? I don't see any details about this in the tutorials that were sent.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
