Multy X WSQ50 Firmware
Mikolka
Mikolka Posts: 3 image  Freshman Member
I have 2 multy x and they do not respond to the app.
They need new firmware. Where can I find it?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @Mikolka ,
    The V2.20(ABKJ.8)C0 firmware version and update instructions have been sent to your community inbox via private message. Please check your inbox to access these materials.
    Zyxel_Judy
    Untitled Image
«13
  • Zyxel_Judy
    Hi @Mikolka ,
    Zyxel_Judy
    Untitled Image
  • tobbot
    tobbot Posts: 2 image  Freshman Member
    May me too last firmware for WSQ50? App show "disconnected".
  • Egunel
    Egunel Posts: 1 image  Freshman Member
    İ need the firmware upgrade for the same device also. Can you please send me upgrade info as well?
  • yngveda
    yngveda Posts: 1 image  Freshman Member
    Same here
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,134 image  Zyxel Employee
    Hi @Egunel @yngveda
    I have sent the file to you. Please chexck your private message.
    Zyxel Melen
  • oleipol
    oleipol Posts: 2 image  Freshman Member
    İ need the firmware upgrade for the same device too. Can you please send me upgrade info as well?
  • MattiaMattia
    MattiaMattia Posts: 2 image  Freshman Member
    Ciao. I need it too. I have 6 multy and 2 of them do not update. Thanks.
  • lucacraft89
    lucacraft89 Posts: 2 image  Freshman Member
    Me too plz
  • Zyxel_Melen
    Hi @lucacraft89
    Sent it to you in private message.
    Zyxel Melen
  • RonDev
    RonDev Posts: 3 image  Freshman Member
    Same here. Mesh suddenly stopped working and the App was not able to connect to the existing Multys.
    Reset and reinstallation impossible.
    @ZyXEL _Melen Could you please also send it to me?
