Nas542 dead + spi_flash_dead + barebox_dead + Uloader_dead
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    / $ /sbin/flash_erase /dev/mtd2 0 0
    flash_erase: error!: /dev/mtd2
    error 13 (Permission denied)
    You are not root. If you are root, you have a # prompt instead of a $
    echo ERROR!!! Invalid INFO value 'curr_bootfrom'!
    Somehow your environment got corrupted again. From your flash.log:
    /firmware/sbin/info_setenv revision_2 51201
    Erasing 64 Kibyte @ 0 -- 0 % complete
    Erasing 64 Kibyte @ 10000 -- 25 % complete
    Erasing 64 Kibyte @ 20000 -- 50 % complete
    Erasing 64 Kibyte @ 30000 -- 75 % complete
    Erasing 64 Kibyte @ 30000 -- 100 % complete
    As you can see each setenv overwrites the whole 256kB mtd2. Maybe it's a good idea to first set some environment variables in the bootloader prompt, in case there is something wrong with the content, after reflashing mtd2. A small corruption could get bigger if info_setenv has a bug. I think the command in the bootloader prompt is simply setenv.
  • stein_990
    stein_990 Posts: 35 image  Freshman Member
    First Answer First Comment Friend Collector
    edited August 2025
    dd if=/mnt/partnerkey/nas540.mtd2 of=/dev/mtd2 bs=64k
    dd: can't open '/dev/mtd2': No such device
    /firmware/sbin/info_printenv
    Open /dev/mtd2 void
    Is there no way out at all now?
  • stein_990
    edited August 2025
    Is it possible to somehow upload the firmware via telnet to create partitions?
  • Mijzelf
    Hm. I wonder if something else is going on. The flash is just a block of, well, flash. The separation in partitions is artificial, and on this box the kernel 'knows' the partitions by it's commandline, which is provided by the bootloader.
    In the bootloader environment you can find
    spi_parts=256k(uloader)ro,512k(barebox)ro,256k(env)
    nand_parts=10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved)
    The bootloader uses this to create a commandline which it passes to the Linux kernel, which you can find back in the kernel bootlog:
    Kernel command line: console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,2048 rootfstype=ubifs rw noinitrd mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved) usb3_internal_clk=yes
    mtdparts defines the mtd partitions. mtd0 is uloader, mdt1 barebox, mtd2 env, and so on.
    By executing 'cat /proc/cmdline' in the telnet shell you can see the kernel commandline. It should be (nearly) identical to the command line above.
    If the mtdparts lacks or is empty, do a printenv in the bootloader prompt, to see if spi_parts and nand_parts are still there. If they are, bootm is apparently not the right way to boot the kernel properly. Try a 'help' in the bootloader prompt.
    Somehow the bootloader should boot the module in /dev/mem the same way as it should boot /dev/nand0.kernel1.bb. The latter is a handle to the 'kernel1' partition on NAND.
  • stein_990
    I can only get into telnet after flashing the kernel, after rebooting and loading from a flash drive. Is it possible to somehow flash your nas540.mtd2 dump in TTL mode? I've been struggling with its recovery for the second day already, yesterday there was hope, but after a successful firmware download everything collapsed(
  • stein_990
    Barebox-C2K >/ printenv
    locals:
    PATH=/env/bin
    ip=dhcp
    kernel_loc=nand
    rootfs_loc=nand
    uloaderimage=microloader-c2kevm.bin
    bareboximage=barebox-c2kevm.bin
    mfg_kernel_img=uImage_MFG
    mfg_rootfs_img=rootfs_ubi.img_MFG
    rootfs_type=ubifs
    rootfsimage=root.ubifs-128k
    kernelimage_type=uimage
    kernelimage=uImage
    spi_device=spi0.0
    nand_device=comcertonand
    rootfs_mtdblock_nand=2
    autoboot_timeout=3
    bootargs=console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,,
    next_bootfrom=2
    curr_bootfrom=1
    kernel_mtd_1=4
    sysimg_mtd_1=5
    kernel_mtd_2=6
    sysimg_mtd_2=7
    MODEL_ID=B103
    globals:
    ~ # cat /proc/cmdline
    Barebox-C2K >/ help
    . - alias for source
    ? - alias for help
    [ - alias for test
    addpart - adds a partition table to a device
    bootm - boot an application image
    bootu - bootu - start a raw linux image
    bootz - bootz - start a zImage
    cat - concatenate file(s)
    cd - change working directory
    clear - clear screen
    copy - copy command
    cp - copy files
    cpuinfo - Show info about CPU
    crc32 - crc32 checksum calculation
    delpart - delete partition(s)
    devinfo - Show information about devices and drivers.
    dhcp - invoke dhcp client to obtain ip/boot params
    echo - echo args to console
    edit - Usage: (s)edit <file>
    erase - erase FLASH memory
    erase_nand - Erase the NAND
    erase_old_nand_fmt - Erase old NAND format
    ethact - set current ethernet device
    exit - exit script
    false - do nothing, unsuccessfully
    gemac_stats - retrieve GEMAC statistics
    getopt - getopt <optstring> <var>
    help - print online help
    i2c_probe - probe for an i2c device
    i2c_read - read from an i2c device
    i2c_write - write to an i2c device
    loadb - Load binary file over serial line (kermit mode)
    loadenv - Load environment from ENVFS into DIRECTORY (default: /dev/env0 -> /env).
    ls - list a file or directory
    md - memory display
    memcmp - memory compare
    memcpy - memory copy
    memset - memory fill
    mkdir - make directories
    mount - Mount a filesystem of a given type to a mountpoint or list mounted filesystems.
    mtest - simple RAM test
    mw - memory write (fill)
    nand - NAND specific handling
    pfe - pfe <options>
    pfe_stats - retrieve PFE statistics
    phy - PHY status, read and write operation
    ping - ping <destination>
    printenv - Print value of one or all environment variables.
    protect - enable flash write protection
    pwd - print working directory
    read_nand - Read the NAND
    readline - prompt for user input
    reset - Perform RESET of the CPU
    rm - remove files
    rmdir - remove directorie(s)
    sata - SATA sub system
    saveenv - save environment to persistent storage
    sedit - alias for edit
    sh - run shell script
    sleep - delay execution for n seconds
    socinfo - print SoC info
    source - execute shell script in current shell environment
    switch - Atheros AR8328 switch read and write operation
    test - minimal test like /bin/sh
    tftp - Load file using tftp protocol
    timeout - wait for a specified timeout
    true - do nothing, successfully
    umount - umount a filesystem
    unprotect - disable flash write protection
    update_i2c - update_i2c <src> <off> <size>
    update_nand - Flash the NAND
    update_nor - Flash the NOR
    update_spi - update_spi <src> <sec> <off> <size>
    version - print monitor version
  • Mijzelf
    edited August 2025
    OK. The command line are the raw bootargs from the environment. So obviously the bootm command is not capable of creating the wanted commandline. Further the environment looks complete. Maybe this are defaults, as the checksums are lacking.
    Anyway, I did some reading in older threads, and found the script /env/bin/boot, which is also stored on mtd2
    When I read it well, it is supposed to boot a raw kernel or module, and create a command line, and do some fan work.
    When called with argument 'tftp', is tries to download a file called uImage, and boots that. So rename the module on your tftpserver to uImage, set the ip and serverip, and try to call the boot script.
    boot tftp
    or, if that fails with something like 'unknown command boot' try
    /env/bin/boot tftp
    Should be possible, the bootloader contains all tools needed to load modules in memory, and to write them in flash. Probably using the command 'update_spi'. But I would be very reluctant to try that. The spi flash contains 256k uloader, 512k barebox and 256k 'mtd2'. If you by accident overwrite the uloader or barebox, you can throw away the box, as there is no bootloader anymore.
  • stein_990
    Hello. I've been wondering for the last few days what could have gone wrong. I used the command you gave me for recording: "dd if=/mnt/partnerkey/nas540.mtd2 of=/dev/mtd2 bs=64k" and the command that helped another person on the forum recover "cat nas540.mtd2.gz | gzip -d | nandwrite /dev/mtd2" is different. Could this have caused the problem? I followed the instructions. I don't know what firmware was installed before all the manipulations, so I installed "abag6". It was successfully flashed, but stopped booting. Now the NAS immediately turns off after pressing the power button, I cleared mtd0 and 1... out of anger... Naturally, now UART doesn't work either... Where are all the bootloaders stored? On the 1Gb Toshiba chip? Is this the end? I just don't understand why after recording mtd2, editing and flashing it, it stopped working then...
  • stein_990
    edited August 2025
    I saw 2 more 8-pin chips (like for BIOS) on the board, with a white dot. What are they for? I have a CH341A programmer.
