Add feature to allow turning off 2.4ghz and 5ghz bands on individual AP's.
Jamiewyc
Jamiewyc Posts: 13 image  Freshman Member
edited July 2024 in Nebula Ideas
Currently, the 2.4ghz and 5ghz bands can only be turned off at SSID level, for all access points. Being able to turn off individual bands on individual AP's is a critical feature that is available on most enterprise WIFI products in order to solve 2.4ghz/5ghz intereference.
If we're trying to reduce interference and we can't stop an AP from broadcasting individual bands, there's nothing we can do. Support mentioned splitting the SSID into two separate 2.4ghz and 5ghz SSID but this is not possible due to the following:
Nebula only allows for 8 SSIDs. I currently have 4 and splitting them would effectively stop me from creating any temporary SSID's that we use (For example, Summer school).
Nebula only allows the creation of 1 SSID with guest vouchers enabled - meaning I wouldn't even be able to split the guest wifi to 2.4 and 5ghz SSIDs.
4 votes
Active · Last Updated
Nebula Tips & Tricks
