Nebula Device status On, but cannot reboot device today at 14:40
Cyber_IT
Cyber_IT Posts: 31 image  Freshman Member
Dear Sir / Madam,
We checked Nebula Device status On, but cannot reboot device, please advise us. Thank you.
Group: Cyber
ORG: Tinson
SITE: HK, VNM
and Device log show as below:
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,136 image  Zyxel Employee
    Hi @Cyber_IT
    Please help to enable Zyxel support access so we can help to check this issue.
    Zyxel Melen
  • Cyber_IT
    Hello Zyxel_Melen,
    already enable. Thank you.
  • Zyxel_Melen
    Hi @Cyber_IT
    I can't find this org in my org list. Could you help to check it again?
    Zyxel Melen
  • Cyber_IT
    Morning Melen,
    Below is Group and Organization information.
  • Cyber_IT
    and here is some device log as below
  • Zyxel_Melen
    Hi @Cyber_IT
    I still not see this group in my list. But please note that, the Nebula Orchestrator/SD-WAN Nebula and the VPN series firewall had reached their End of life (EOL) status, which means the support we can provide is limited.
    We want to clarify if this issue is because the device didn't take the reboot action/process. Could you help to power off the device(about 30 second) and power on it? If this doesn't help. We recommend to upgrade your firewall to USG FLEX H series for optimal performance and support.
    Zyxel Melen
  • Cyber_IT
    Hello Melen,
    But the case is same as my post on August 2023, all device cannot through nebula orchestrator reboot device. Then the issue is fixed by your team. Thank you.
  • Cyber_IT
    https://community.zyxel.com/en/discussion/18492/nebula-device-status-on-but-cannot-reboot-device-today#latest
  • Zyxel_Melen
    Hi @Cyber_IT
    We did some adjustment on the server side, could you help to check if this helps?
    Zyxel Melen
  • Cyber_IT
    Hello Melen,
    Thank you for your help and now is resume. But may i know is our problem? or next time also will have this issue? Thank you.
Nebula Tips & Tricks
