Nebula Device status On, but cannot reboot device today at 14:40
Hi @Cyber_IT
Please help to enable Zyxel support access so we can help to check this issue.
Zyxel Melen0 -
Hello Zyxel_Melen,
already enable. Thank you.
Morning Melen,
Below is Group and Organization information.0 -
and here is some device log as below
Hi @Cyber_IT
I still not see this group in my list. But please note that, the Nebula Orchestrator/SD-WAN Nebula and the VPN series firewall had reached their End of life (EOL) status, which means the support we can provide is limited.
We want to clarify if this issue is because the device didn't take the reboot action/process. Could you help to power off the device(about 30 second) and power on it? If this doesn't help. We recommend to upgrade your firewall to USG FLEX H series for optimal performance and support.
Zyxel Melen0 -
Hello Melen,
But the case is same as my post on August 2023, all device cannot through nebula orchestrator reboot device. Then the issue is fixed by your team. Thank you.
https://community.zyxel.com/en/discussion/18492/nebula-device-status-on-but-cannot-reboot-device-today#latest
Hi @Cyber_IT
We did some adjustment on the server side, could you help to check if this helps?
Zyxel Melen0 -
Hello Melen,
Thank you for your help and now is resume. But may i know is our problem? or next time also will have this issue? Thank you.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
